Introduction
Use this guide to replace the left speaker in a 2018 MacBook Air. This is the speaker on the USB-C port side of the case.
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the left speaker, enough so you can grab it with your fingers.
Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
If the adhesive strip breaks, leave it in and proceed to the next step.
Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
Use tweezers to lift the adhesive pull tab at the top of the left speaker enough that you can grab it with your fingers.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
