Replacing MacBook Air 11" Mid 2013 I/O Board
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board: step 1, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board: step 1, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board: step 1, image 3 of 3
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  2. Replacing MacBook Air 11" Mid 2013 I/O Board: step 2, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 2, image 2 of 2
    • Use tweezers to remove any tape covering the microphone cable ZIF connector.
  3. Replacing MacBook Air 11" Mid 2013 I/O Board: step 3, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 3, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 3, image 3 of 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  4. Replacing MacBook Air 11" Mid 2013 I/O Board: step 4, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 4, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 4, image 3 of 3
    • Use the tip of a spudger to pry under the speaker cable near the connector lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  5. Replacing MacBook Air 11" Mid 2013 I/O Board: step 5, image 1 of 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  6. Replacing MacBook Air 11" Mid 2013 I/O Board: step 6, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 6, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 6, image 3 of 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Sam Goldheart
466,931 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
