MacBook Air 11" Mid 2013 I/O Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: step 1, image 1 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: step 1, image 2 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: step 1, image 3 of 3
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  2. MacBook Air 11" Mid 2013 I/O Board Replacement: step 2, image 1 of 2 MacBook Air 11" Mid 2013 I/O Board Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  3. MacBook Air 11" Mid 2013 I/O Board Replacement: step 3, image 1 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 3, image 2 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 3, image 3 of 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  4. MacBook Air 11" Mid 2013 I/O Board Replacement: step 4, image 1 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 4, image 2 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 4, image 3 of 3
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  5. MacBook Air 11" Mid 2013 I/O Board Replacement: step 5, image 1 of 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  6. MacBook Air 11" Mid 2013 I/O Board Replacement: step 6, image 1 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 6, image 2 of 3 MacBook Air 11" Mid 2013 I/O Board Replacement: step 6, image 3 of 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Sam Goldheart
466,931 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
