Shop the Holiday Gift Guide
MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement
Views: 36K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
129
All Time:
36,245
Comments: 116
114 comments on steps, 2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace the I/O board, which includes the SD card slot, the HDMI port and the right USB port.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Parts
Tools
    1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 2, image 1 of 1
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 3, image 2 of 2
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Battery Connector: step 4, image 1 of 1
      • If necessary, remove the plastic cover adhered to the battery contact board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 6, image 1 of 1
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Heat Sink: step 7, image 3 of 3
      • Carefully remove the rubber fan bumper from the edge of the heat sink.
      • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 9, image 1 of 1
      • Remove the following screws securing the heat sink to the logic board:
      • Four 2.6 mm T5 screws
      • One 2.4 mm Phillips #000 screw
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 10, image 2 of 2
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Fan: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, Fan: step 11, image 2 of 2
      • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 12, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 12, image 2 of 2
      • Peel the iSight camera cable off the fan housing to fold it out of the way.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 13, image 3 of 3
      • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
      • Carefully pull the fan cable straight out of its socket.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 14, image 1 of 1
      • Remove the following screws securing the fan to the upper case:
      • One 5.0 mm T5 Torx screw
      • Two 3.6 mm T5 Torx screws
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 15, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 15, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 15, image 3 of 3
      • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
      Ask FixBot
    1. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: step 16, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: step 16, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement, I/O Board: step 16, image 3 of 3
      • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
      • The three cables are coded with black sleeves of different lengths. During reassembly:
      • Connect the long-sleeved cable to the center socket.
      • The short-sleeved cable connects next to the screw.
      • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 17, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 17, image 2 of 2
      • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket.
      • Remove the I/O board cable bracket.
      Ask FixBot
    3. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 18, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 18, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 18, image 3 of 3
      • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the I/O board.
      • Be careful to only pry up on the cable connector, not on the socket itself or you risk damaging your I/O board.
      • Push the I/O board cable up to bend it out of the way.
      Ask FixBot
    4. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 19, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 19, image 2 of 2
      • Use the tip of a spudger to push on either side of the I/O board connector to walk it out of its socket on the logic board.
      Ask FixBot
    5. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 20, image 1 of 1
      • Remove the following screws securing the I/O board to the upper case:
      • One 3.5 mm T8 Torx standoff screw
      • One 3.5 mm T5 Torx screw
      Ask FixBot
    6. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 21, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 21, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 21, image 3 of 3
      • Lift the I/O board cable end of the I/O board and pull toward the logic board to free the ports from the upper case.
      • Remove the I/O board.
      Ask FixBot
    7. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 22, image 1 of 1
      • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
      Ask FixBot
    8. MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 23, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 23, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 I/O Board Replacement: step 23, image 3 of 3
      • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the I/O board.
      Ask FixBot
20 other people completed this guide.
Sam Goldheart
478,714 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
120 Members
72,955 Guides authored
2 Guide Comments
Thank you! My Macbook was not starting anymore and I saw that it will boot without the IO board. I got a new part, exchanged it and it is now working flawlessly.
winterchristian - Reply Share
This is missing a crusial step: the right speaker has to come out!
Wenchao Liu - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 129
All Time: 36,245
