Mac mini Model A1283 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac mini Model A1283 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
  2. Mac mini Model A1283 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
  3. Mac mini Model A1283 Hard Drive Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the hard drive thermal sensor board off the adhesive securing it to the side of the hard drive.
  4. Mac mini Model A1283 Hard Drive Replacement: step 4, image 1 of 1
    • Remove the strip of tape holding the thermal sensor cable to the hard drive and remove the thermal sensor from the hard drive.
    • You'll want to transfer this thermal sensor to the same position on your new hard drive.
  5. Mac mini Model A1283 Hard Drive Replacement: step 5, image 1 of 2 Mac mini Model A1283 Hard Drive Replacement: step 5, image 2 of 2
    • Slide the hard drive toward the speaker to disconnect it from the interconnect board.
    • Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 2,090
