Introduction
Accessing and removing the power supply unit is relatively straightforward, and will require a 2mm Hex screwdriver.
Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
Firmly hold each of the two connectors and pull them out of their respective sockets.
Remove the 4 marked 6-32 hex screws with a 2mm Phillips hex screwdriver.
Grip the handle on the left side of the power supply casing while gripping the right side of the power supply casing and pull upwards firmly to to take it out.
For the Mac Pro (Early 2008/9), a.k.a. MacPro3,1 In the MacPro3,1, the power supply screws are 2.5mm hex, not T-10. Also, there is a cover plate behind the superdrive that has to be removed (2 phillips screws) to expose the power cable connections and those connectors must be detached and slid under fan before the power supply can be removed.
Locate the four marked cables
Push down on the clip that is above each cable connector while firmly grasping each connector and pull each one back to remove each clip.
