Mac Pro First Generation GPU Replacement
  1. Mac Pro First Generation GPU Replacement, Case Panel: step 1, image 1 of 1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation GPU Replacement: step 2, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): step 3, image 1 of 1
    • Locate the graphics card in the open panel side of your Mac Pro.
  4. Mac Pro First Generation GPU Replacement: step 4, image 1 of 3 Mac Pro First Generation GPU Replacement: step 4, image 2 of 3 Mac Pro First Generation GPU Replacement: step 4, image 3 of 3
    • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
    • Remove the slide lock.
  5. Mac Pro First Generation GPU Replacement: step 5, image 1 of 2 Mac Pro First Generation GPU Replacement: step 5, image 2 of 2
    • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
Andrew Kim
1,263 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Fall 2014 Member of Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 63
All Time: 22,031
