Mac Mini Late 2014 Fan Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Mini Late 2014 Fan Replacement, Fan Assembly: step 1, image 1 of 1
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw.
  2. Mac Mini Late 2014 Fan Replacement: step 2, image 1 of 3 Mac Mini Late 2014 Fan Replacement: step 2, image 2 of 3 Mac Mini Late 2014 Fan Replacement: step 2, image 3 of 3
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  3. Mac Mini Late 2014 Fan Replacement: step 3, image 1 of 2 Mac Mini Late 2014 Fan Replacement: step 3, image 2 of 2
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  4. Mac Mini Late 2014 Fan Replacement: step 4, image 1 of 1
    • Remove the fan from the Mac Mini.
Sam Goldheart
465,854 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 12
All Time: 252
