Introduction
Prerequisite only
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw - it will get removed with the fan assembly.
Lift the fan straight up to free the captive screw from its hole in the logic board.
Pull the fan away from the SSD until you can easily access the fan connector.
Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
