Mac Laptop Feet Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Laptop Feet Replacement, Feet: step 1, image 1 of 3 Mac Laptop Feet Replacement, Feet: step 1, image 2 of 3 Mac Laptop Feet Replacement, Feet: step 1, image 3 of 3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  2. Mac Laptop Feet Replacement: step 2, image 1 of 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  3. Mac Laptop Feet Replacement: step 3, image 1 of 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  4. Mac Laptop Feet Replacement: step 4, image 1 of 1
    • Peel a replacement foot from the plastic backing.
  5. Mac Laptop Feet Replacement: step 5, image 1 of 3 Mac Laptop Feet Replacement: step 5, image 2 of 3 Mac Laptop Feet Replacement: step 5, image 3 of 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  6. Mac Laptop Feet Replacement: step 6, image 1 of 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive.
    • Repeat the last six steps for any broken or damaged feet.
Arthur Shi
254,564 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 326
