Mac Laptop 2009-2012 Feet Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Laptop 2009-2012 Feet Replacement, Feet: step 1, image 1 of 3 Mac Laptop 2009-2012 Feet Replacement, Feet: step 1, image 2 of 3 Mac Laptop 2009-2012 Feet Replacement, Feet: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  2. Mac Laptop 2009-2012 Feet Replacement: step 2, image 1 of 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  3. Mac Laptop 2009-2012 Feet Replacement: step 3, image 1 of 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  4. Mac Laptop 2009-2012 Feet Replacement: step 4, image 1 of 1
    • Peel a replacement foot from the plastic backing.
  5. Mac Laptop 2009-2012 Feet Replacement: step 5, image 1 of 3 Mac Laptop 2009-2012 Feet Replacement: step 5, image 2 of 3 Mac Laptop 2009-2012 Feet Replacement: step 5, image 3 of 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  6. Mac Laptop 2009-2012 Feet Replacement: step 6, image 1 of 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Arthur Shi
298,265 Reputation
683 Guides authored
iFixit Member of iFixit
Staff
119 Members
21,911 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 360
