MSI GT72 2QE Dominator Pro Fans Replacement
  1. MSI GT72 2QE Dominator Pro Fans Replacement, Fans: step 1, image 1 of 1
    • Remove the seven 6 mm Phillips #00 screws on the back cover of the laptop with the PH0 Bit screwdriver.
    • Every screw in this guide can be removed with the same PH0 Bit screwdriver.
  2. MSI GT72 2QE Dominator Pro Fans Replacement: step 2, image 1 of 1
    • Lift the back cover off by lifting by the tab on the bottom of the cover as indicated.
  3. MSI GT72 2QE Dominator Pro Fans Replacement: step 3, image 1 of 2 MSI GT72 2QE Dominator Pro Fans Replacement: step 3, image 2 of 2
    • Detach the two indicated wires by pulling upward on them.
  4. MSI GT72 2QE Dominator Pro Fans Replacement: step 4, image 1 of 1
    • Unscrew a total of four 10mm Philips #00 screws (two screws per fan) as indicated.
Michael Petralia
191 Reputation
1 Guide authored
Cal Poly, Team S17-G2, Banghart Spring 2017 Member of Cal Poly, Team S17-G2, Banghart Spring 2017
CPSU-BANGHART-S17S17G2
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,928
