MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement
  1. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: step 1, image 1 of 3 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: step 1, image 2 of 3 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement, Hard disk drive: step 1, image 3 of 3
    • Remove the eleven 5mm screws with a PH0 bit.
    • Remove the four 2.5mm screws with a PH0 bit.
    • Remove the bottom cover
  2. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: step 2, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: step 2, image 2 of 2
    • Locate the hard drive
    • Unplug the selected white wire located above the hard drive.
    • Unplug it gently by lifting it up to unlock the black cover that connects it to the motherboard. Do not break the black cover
  3. MSI GS60 6QE GHOST PRO 4K Hard disk drive Replacement: step 3, image 1 of 1
    • Unplug the hard drive gently.
Mafdy Wahib
369 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Nance Fall 2017 Member of USF Tampa, Team S1-G4, Nance Fall 2017
USFT-NANCE-F17S1G4
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,837
