Introduction
The hard drive is one of the easiest parts that can be replaced in the device. The only thing is do it with caution and not to cause any damages to the other wires next to it. Hard drive is clearly visible under the bottom cover and has only one wire above that needs to be disconnected.
Remove the 15 screws that hold the bottom cover. unscrew it with PH0 Bit screwdriver
The red circles indicate that the screws be unscrewed from that position are the 5 mm length screw.
The holes highlighted in orange are the 2.5 mm length screws.
Remove the bottom cover
