Shop the Holiday Gift Guide
Lower Feet Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
21
All Time:
168
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Lower Feet Removal
Introduction
Go to step 1 ↓
This guide shows how to remove the three lower feet on your Logitech K540 wireless keyboard. If you're opening the keyboard up, you only need to remove these feet.
Tools
    1. Lower Feet Removal, Prepare your keyboard for disassembly: step 1, image 1 of 2 Lower Feet Removal, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the power switch on the top right corner to the OFF position.
      • Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. Lower Feet Removal, Remove the three feet: step 2, image 1 of 3 Lower Feet Removal, Remove the three feet: step 2, image 2 of 3 Lower Feet Removal, Remove the three feet: step 2, image 3 of 3
      • Light adhesive secures the three rubber feet along the edge of the keyboard. If you're having trouble removing them, use an iOpener or hair dryer to lightly heat them.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      Ask FixBot
    2. Lower Feet Removal: step 3, image 1 of 2 Lower Feet Removal: step 3, image 2 of 2
      • Repeat the previous step to remove the two remaining feet.
      Ask FixBot
Finish Line
Spencer Day
210,419 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 168
