Lorex LHV210800 Button Panel Replacement
    1. Lorex LHV210800 Button Panel Replacement, Upper Case: step 1, image 1 of 3 Lorex LHV210800 Button Panel Replacement, Upper Case: step 1, image 2 of 3 Lorex LHV210800 Button Panel Replacement, Upper Case: step 1, image 3 of 3
      • Before beginning, disconnect the DVR from power and unplug all peripheries.
      • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
      Ask FixBot
    2. Lorex LHV210800 Button Panel Replacement: step 2, image 1 of 2 Lorex LHV210800 Button Panel Replacement: step 2, image 2 of 2
      • Remove the four 1 cm Phillips screws on the rear panel.
      • Do not unscrew the screw connected to the lower case.
      Ask FixBot
    3. Lorex LHV210800 Button Panel Replacement: step 3, image 1 of 1
      • Lift up and remove the top cover.
      Ask FixBot
    1. Lorex LHV210800 Button Panel Replacement, Button Panel: step 4, image 1 of 2 Lorex LHV210800 Button Panel Replacement, Button Panel: step 4, image 2 of 2
      • Unplug the two cables from the HDD.
      • These plugs will have a BLUE and R/B/B/Y color scheme.
      Ask FixBot
    2. Lorex LHV210800 Button Panel Replacement: step 5, image 1 of 1
      • Flip the DVR over so the underside is facing up.
      • Remove the 1 cm Phillips screws on the lower case.
      Ask FixBot
    3. Lorex LHV210800 Button Panel Replacement: step 6, image 1 of 1
      • Lift the HDD up and out of the chassis.
      Ask FixBot
    4. Lorex LHV210800 Button Panel Replacement: step 7, image 1 of 1
      • Remove the five Phillips screws that secure the button panel.
      Ask FixBot
    5. Lorex LHV210800 Button Panel Replacement: step 8, image 1 of 1
      • Depress the white clip that secures the button panel connector.
      • Disconnect the white button panel connector.
      Ask FixBot
    6. Lorex LHV210800 Button Panel Replacement: step 9, image 1 of 2 Lorex LHV210800 Button Panel Replacement: step 9, image 2 of 2
      • Release the retaining tabs that secure the button panel ribbon cable.
      • Disconnect the ribbon cable.
      • Remove the button panel.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Maxwell Cash
387 Reputation
3 Guides authored
2 Guide Comments
In the details section, there is no time estimation. It took our group 13 minutes to disassemble the dvr and put it back together.
Joshua Anderson - Reply Share
In the details section it does not list the tools needed.
Anthony - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 68
All Time: 618
