Shop the Holiday Gift Guide
Logitech Zone 305 Battery Steps
View statistics:
Past 24 Hours:
2
Past 7 Days:
2
Past 30 Days:
10
All Time:
110
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Logitech Zone 305 battery steps prereq
Parts
Tools
    1. Logitech Zone 305 Battery Steps, Separate the speaker plate: step 1, image 1 of 3 Logitech Zone 305 Battery Steps, Separate the speaker plate: step 1, image 2 of 3 Logitech Zone 305 Battery Steps, Separate the speaker plate: step 1, image 3 of 3
      • Insert the point of an opening pick into the seam between the speaker plate and ear cup.
      • Slide the pick along the seam to release the four speaker plate clips.
      Ask FixBot
    2. Logitech Zone 305 Battery Steps: step 2, image 1 of 3 Logitech Zone 305 Battery Steps: step 2, image 2 of 3 Logitech Zone 305 Battery Steps: step 2, image 3 of 3
      • Don't try to fully remove the speaker plate, as a wire connects it to the ear cup.
      • Use your fingers to move the speaker plate towards the right side of the ear cup so you can access the screw.
      Ask FixBot
    3. Logitech Zone 305 Battery Steps, Separate the speaker housing: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the 7.1 mm‑long pancake screw securing the speaker housing.
      Ask FixBot
    4. Logitech Zone 305 Battery Steps: step 4, image 1 of 1
      • This step reattaches the speaker plate temporarily to keep it from wobbling during repairs.
      • Align the speaker plate to the speaker housing and squeeze firmly to engage two of the four clips.
      Ask FixBot
    5. Logitech Zone 305 Battery Steps: step 5, image 1 of 2 Logitech Zone 305 Battery Steps: step 5, image 2 of 2
      • Use your fingers to grab the speaker housing from the back.
      • Pull firmly to pop the housing off from its ball joint.
      • Be careful not to pull too far—a speaker wire still connects the housing and the ear cup.
      Ask FixBot
    6. Logitech Zone 305 Battery Steps, Remove the midplate screws: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the three 5.3 mm‑long screws securing the midplate.
      Ask FixBot
    7. Logitech Zone 305 Battery Steps, Reposition the midplate: step 7, image 1 of 3 Logitech Zone 305 Battery Steps, Reposition the midplate: step 7, image 2 of 3 Logitech Zone 305 Battery Steps, Reposition the midplate: step 7, image 3 of 3
      • Be careful not to strain the speaker and battery cables during this step.
      • Insert an opening pick in the seam between the midplate and the ear cup.
      • Twist the pick to loosen the midplate.
      • Use your fingers to swing the midplate away from the ear cup.
      Ask FixBot
    8. Logitech Zone 305 Battery Steps, Remove the battery: step 8, image 1 of 3 Logitech Zone 305 Battery Steps, Remove the battery: step 8, image 2 of 3 Logitech Zone 305 Battery Steps, Remove the battery: step 8, image 3 of 3
      • The battery's lightly adhered to the midplate.
      • Slide the tip of an opening pick under the battery and pry gently to separate it from the midplate.
      Ask FixBot
    9. Logitech Zone 305 Battery Steps: step 9, image 1 of 2 Logitech Zone 305 Battery Steps: step 9, image 2 of 2
      • Use your fingers to peel and remove the foam pad covering the circuit board.
      • Store this pad in a clean location for reassembly.
      Ask FixBot
    10. Logitech Zone 305 Battery Steps: step 10, image 1 of 3 Logitech Zone 305 Battery Steps: step 10, image 2 of 3 Logitech Zone 305 Battery Steps: step 10, image 3 of 3
      • Use angled tweezers to grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide the battery connector out of its socket.
      • This connector can be difficult to disconnect. Squeeze the tweezers close to the tips to help grip the connector.
      Ask FixBot
    11. Logitech Zone 305 Battery Steps: step 11, image 1 of 1
      • Remove the battery.
      Ask FixBot
    12. Logitech Zone 305 Battery Steps, Install the battery: step 12, image 1 of 2 Logitech Zone 305 Battery Steps, Install the battery: step 12, image 2 of 2
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • The remaining instructions show how to reassemble the headset.
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Remove the liner to expose the adhesive.
      Ask FixBot
    13. Logitech Zone 305 Battery Steps: step 13, image 1 of 2 Logitech Zone 305 Battery Steps: step 13, image 2 of 2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      Ask FixBot
    14. Logitech Zone 305 Battery Steps: step 14, image 1 of 1
      • Place the foam pad over the circuit board and use your finger to press it in place.
      Ask FixBot
    15. Logitech Zone 305 Battery Steps: step 15, image 1 of 1
      • Align the battery in the midplate recess such that the battery cable reaches its circuit board connector.
      • Use your fingers to press the battery onto the midplate.
      Ask FixBot
    16. Logitech Zone 305 Battery Steps, Install the midplate: step 16, image 1 of 2 Logitech Zone 305 Battery Steps, Install the midplate: step 16, image 2 of 2
      • Swing the midplate back in place over the ear cup.
      Ask FixBot
    17. Logitech Zone 305 Battery Steps: step 17, image 1 of 1
      • Use a Phillips screwdriver to install the three 5.3 mm‑long screws to secure the midplate.
      Ask FixBot
    18. Logitech Zone 305 Battery Steps: step 18, image 1 of 1
      • At this point, you'll need to separate the speaker plate you partially reattached earlier to reinstall the pancake screw.
      • Use your fingers to unclip the speaker plate from the housing.
      Ask FixBot
    19. Logitech Zone 305 Battery Steps, Install the speaker housing: step 19, image 1 of 1
      • Align the speaker housing to the midplate such that the speaker wire threads through both parts without twisting.
      Ask FixBot
    20. Logitech Zone 305 Battery Steps: step 20, image 1 of 2 Logitech Zone 305 Battery Steps: step 20, image 2 of 2
      • Align the ball joint to the speaker housing's center cutout.
      • Use your fingers to firmly press the speaker housing onto the ball joint to pop it back in place.
      Ask FixBot
    21. Logitech Zone 305 Battery Steps: step 21, image 1 of 1
      • Use a Phillips screwdriver to install the 7.1 mm‑long pancake screw to secure the speaker housing.
      Ask FixBot
    22. Logitech Zone 305 Battery Steps: step 22, image 1 of 2 Logitech Zone 305 Battery Steps: step 22, image 2 of 2
      • Use your fingers to move the speaker plate back over the speaker housing.
      • The top clip is wider than the rest of the clips. Use this to help align the speaker plate to the housing.
      Ask FixBot
    23. Logitech Zone 305 Battery Steps: step 23, image 1 of 3 Logitech Zone 305 Battery Steps: step 23, image 2 of 3 Logitech Zone 305 Battery Steps: step 23, image 3 of 3
      • Use your fingers to squeeze and engage the four clips to secure the speaker plate to the housing.
      Ask FixBot
Author
with
Arthur Shi
353,984 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 110
