Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Logitech Zone 300 battery removal and installation steps prereq
Parts
Tools
Insert the point of an opening pick into the seam between the speaker plate and ear cup.
Slide the pick along the seam to release the four speaker plate clips.
Use a Phillips screwdriver to remove the 7.1 mm‑long pancake screw securing the speaker housing.
Use a Phillips screwdriver to remove the three 5.3 mm‑long screws securing the midplate.
Slide the tip of an opening pick under the battery and pry gently to separate it from the midplate.
Tool used on this step:Tesa 61395 Tape$2.95
Cut and attach a small strip of double-sided tape onto the battery.
Remove the adhesive liner to expose the adhesive.
Use your fingers to unclip the speaker plate from the housing.
Use your fingers to move the speaker plate back over the speaker housing.
The top clip is wider than the rest of the clips and is located above a set of vent holes. Use this to help align the speaker plate to the housing.
