Logitech VX Nano Wireless Mouse Opening Procedure
    1. Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: step 1, image 1 of 2 Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: step 1, image 2 of 2
      • Pull down on the battery release tab to remove the battery cover.
      • Remove battery cover.
      Ask FixBot
    2. Logitech VX Nano Wireless Mouse Opening Procedure: step 2, image 1 of 2 Logitech VX Nano Wireless Mouse Opening Procedure: step 2, image 2 of 2
      • Pull the battery release tab away from the mouse so the two AA batteries come out.
      Ask FixBot
    3. Logitech VX Nano Wireless Mouse Opening Procedure: step 3, image 1 of 1
      • If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
      Ask FixBot
    4. Logitech VX Nano Wireless Mouse Opening Procedure, Open the mouse: step 4, image 1 of 1
      • Find and remove the screws at the bottom of the battery compartment:
      • Two 6 mm Phillips #1 screws
      • When removing these two screws, it can be helpful to hold the plastic battery tab out of the way of your screwdriver.
      Ask FixBot
    5. Logitech VX Nano Wireless Mouse Opening Procedure: step 5, image 1 of 2 Logitech VX Nano Wireless Mouse Opening Procedure: step 5, image 2 of 2
      • Use an opening pick to get underneath the corner of one of the adhesive skates.
      • As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
      • Continue to push the opening pick between the adhesive and the mouse case, slowly working the adhesive away from the case.
      • Repeat this same process for the two other skates.
      • Remove any old adhesive residue before applying new mouse skates.
      Ask FixBot
    6. Logitech VX Nano Wireless Mouse Opening Procedure: step 6, image 1 of 1
      • Remove the screws from the backside of the mouse:
      • Three 6 mm Phillips #1 screws
      • The top shell and bottom case are no longer connected. Keep the mouse steady so you can carefully remove the upper shell in the next step.
      Ask FixBot
    7. Logitech VX Nano Wireless Mouse Opening Procedure: step 7, image 1 of 2 Logitech VX Nano Wireless Mouse Opening Procedure: step 7, image 2 of 2
      • Carefully separate the top plastic shell from the bottom case.
      • Remove the top shell.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Carsten Frauenheim
171,406 Reputation
442 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 74
All Time: 538
