Logitech UE Megaboom 4 Power Button Board Replacement
    1. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: step 1, image 1 of 3 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: step 1, image 2 of 3 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: step 1, image 3 of 3
      • Place the end of a metal spudger in the seam between the top cover and outer case of the speaker. Work your way around the seam of the cover to loosen it.
      • This will take force as it is glued down with the waterproofing sealant.
      • Be careful when using the metal spudger. It is sharp and can cause damage to your device and yourself.
      • Separate the top cover of the speaker from the case.
      Ask FixBot
    2. Logitech UE Megaboom 4 Power Button Board Replacement: step 2, image 1 of 2 Logitech UE Megaboom 4 Power Button Board Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove four screws from the underside of the top cover of the speaker.
      • Remove the black bracket covering the button board.
      Ask FixBot
    3. Logitech UE Megaboom 4 Power Button Board Replacement: step 3, image 1 of 1
      • Remove the circuit board from the cap.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 70
All Time: 404
