Logitech UE Megaboom 4 Outer Case Replacement
    1. Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: step 1, image 1 of 3 Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: step 1, image 2 of 3 Logitech UE Megaboom 4 Outer Case Replacement, Outer Case: step 1, image 3 of 3
      • Flip your speaker upside down so the charging port side is faced upwards.
      • Place the end of a metal spudger in between the rubber bottom and the mesh case.
      • Work your way around the base of the speaker until the top separates from the case of the speaker.
      • This will take force.
      • Use the metal spudger carefully. Improper use may lead to injury.
      Ask FixBot
    2. Logitech UE Megaboom 4 Outer Case Replacement: step 2, image 1 of 1
      • Pull the bottom end of the speaker off and place it aside.
      • Once the glued seal is broken you will be able to pull it off with your hands.
      Ask FixBot
    3. Logitech UE Megaboom 4 Outer Case Replacement: step 3, image 1 of 3 Logitech UE Megaboom 4 Outer Case Replacement: step 3, image 2 of 3 Logitech UE Megaboom 4 Outer Case Replacement: step 3, image 3 of 3
      • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
      • The inside components will begin to slide out of the top from the mesh casing.
      Ask FixBot
    4. Logitech UE Megaboom 4 Outer Case Replacement: step 4, image 1 of 1
      • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 65
All Time: 401
