Introduction
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom power button.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
Locate the end of the speaker which contains the power button.
Grasp the outer rim of this end cap and pull in an upward motion.
Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
Using your fingers lift the board out of place.
