Introduction
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom Auxiliary and USB Ports.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Apply an upward force with your thumbs to loosen the end cap.
Grasp the end cap and lift up to seperate it from the base.
Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
Push up on the rectangular connector from the bottom to loosen the circuit board.
Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
