Logitech UE Boom Lithium Battery Replacement
  1. Logitech UE Boom Lithium Battery Replacement, D-ring: step 1, image 1 of 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom Lithium Battery Replacement: step 2, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 2, image 2 of 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom Lithium Battery Replacement, Bluetooth Adapter: step 3, image 1 of 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. Logitech UE Boom Lithium Battery Replacement: step 4, image 1 of 3 Logitech UE Boom Lithium Battery Replacement: step 4, image 2 of 3 Logitech UE Boom Lithium Battery Replacement: step 4, image 3 of 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom Lithium Battery Replacement: step 5, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 5, image 2 of 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom Lithium Battery Replacement: step 6, image 1 of 3 Logitech UE Boom Lithium Battery Replacement: step 6, image 2 of 3 Logitech UE Boom Lithium Battery Replacement: step 6, image 3 of 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
  7. Logitech UE Boom Lithium Battery Replacement: step 7, image 1 of 1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. Logitech UE Boom Lithium Battery Replacement, Lithium Battery: step 8, image 1 of 1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. Logitech UE Boom Lithium Battery Replacement: step 9, image 1 of 1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
  10. Logitech UE Boom Lithium Battery Replacement: step 10, image 1 of 3 Logitech UE Boom Lithium Battery Replacement: step 10, image 2 of 3 Logitech UE Boom Lithium Battery Replacement: step 10, image 3 of 3
    • Peel off the sleeve.
  11. Logitech UE Boom Lithium Battery Replacement: step 11, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 11, image 2 of 2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. Logitech UE Boom Lithium Battery Replacement: step 12, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 12, image 2 of 2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. Logitech UE Boom Lithium Battery Replacement: step 13, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 13, image 2 of 2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. Logitech UE Boom Lithium Battery Replacement: step 14, image 1 of 1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. Logitech UE Boom Lithium Battery Replacement: step 15, image 1 of 1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. Logitech UE Boom Lithium Battery Replacement: step 16, image 1 of 2 Logitech UE Boom Lithium Battery Replacement: step 16, image 2 of 2
    • Remove the battery by pulling it from the terminal as marked in the picture.
Jose Cruz Arinaga
1,003 Reputation
3 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
22 Guides authored
Past 24 Hours: 48
Past 7 Days: 298
Past 30 Days: 1,338
All Time: 116,237
