Logitech Signature M650 L Scroll Wheel Assembly Replacement
    1. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: step 1, image 1 of 3 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: step 1, image 2 of 3 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: step 1, image 3 of 3
      • Slide the battery compartment cover downward and lift it away from the mouse.
      Ask FixBot
    2. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 2, image 1 of 1
      • Remove the AA battery from the battery compartment.
      Ask FixBot
    3. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 3, image 1 of 2 Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 3, image 2 of 2
      • Remove the USB receiver from its storage slot inside the battery compartment.
      Ask FixBot
    4. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 4, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the two screws securing the internal frame.
      Ask FixBot
    5. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 5, image 1 of 2 Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 5, image 2 of 2
      • Gently lift the top shell away from the mouse body.
      • Do not remove it completely, as it is still connected to the base by a cable.
      Ask FixBot
    6. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 6, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the two screws securing the scroll wheel assembly.
      Ask FixBot
    7. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 7, image 1 of 2 Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 7, image 2 of 2
      • Lift the scroll wheel assembly out of the mouse and install the replacement assembly in the same position.
      Ask FixBot
    8. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 8, image 1 of 1
      • Replace the two Phillips #000 screws to secure the scroll wheel assembly.
      Ask FixBot
    9. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 9, image 1 of 1
      • Align the top shell with the base and press down along the edges until it snaps into place.
      Ask FixBot
    10. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 10, image 1 of 1
      • Use a Phillips #000 screwdriver to reinstall the two internal screws.
      Ask FixBot
    11. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 11, image 1 of 3 Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 11, image 2 of 3 Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 11, image 3 of 3
      • Insert the AA battery, reinstall the USB receiver, and slide the battery compartment cover back into place.
      Ask FixBot
    12. Logitech Signature M650 L Scroll Wheel Assembly Replacement: step 12, image 1 of 1
      • Your mouse is now fully reassembled.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 166
All Time: 454
