Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Follow this guide to replace the slip ring in your Logitech RS50 Base.
Tools
Spudger4.9
Congratulations on completing disassembly! The remaining steps will show how to reassemble your device.
Peel the opaque yellow liner from the slip ring adhesive strip.
Thread the slip ring's short cable through the back of the slip ring adapter (the end with the arms).
Push the slip ring into the adapter until it's fully seated with no room to move.
Insert the slip ring's long cable into the back of the shaft and guide it through to the front.
Slowly lower the circuit board in place, threading the slip ring cable through its cutout.
Use your fingers to slide the ballast temperature connector fully into its socket to connect it.
Repeat for the ballast connector above it.
Use tweezers to hold the slip ring connector near the base and connect it to the QR adapter socket.
