Logitech RS Shifter & Handbrake USB Cable Replacement
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Before you begin: step 1, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Before you begin: step 1, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin your repair:
      • Unplug the shifter's USB cable.
      • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
      • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the handle: step 2, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the handle: step 2, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the handle: step 2, image 3 of 3
      • Twist the handle counterclockwise to unscrew and remove it.
      • Grip the knurled section of the handle, not the collar at the base.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the top cover: step 3, image 2 of 2
      • Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
      Ask FixBot
    2. Logitech RS Shifter & Handbrake USB Cable Replacement: step 4, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement: step 4, image 2 of 2
      • Lift the top cover straight up to remove it—the metal shift gate is sitting loosely in the cover.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the chassis: step 5, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the chassis: step 5, image 2 of 2
      • Remove the eight screws securing the chassis:
      • Four 10 mm‑long 2.5 mm hex screws
      • Four 12 mm‑long Phillips screws
      Ask FixBot
    2. Logitech RS Shifter & Handbrake USB Cable Replacement: step 6, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement: step 6, image 2 of 2
      • Lift the chassis straight up and remove it.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the midframe: step 7, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the midframe: step 7, image 2 of 2
      • Use a long-shank Phillips screwdriver to remove the six 12 mm‑long screws securing the midframe.
      • During reassembly, make sure you install the screws through the plastic midframe, not the large holes on the metal baseplate.
      Ask FixBot
    2. Logitech RS Shifter & Handbrake USB Cable Replacement: step 8, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement: step 8, image 2 of 2
      • Lift the midframe straight up and remove it.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Disconnect the cables: step 9, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Disconnect the cables: step 9, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Disconnect the cables: step 9, image 3 of 3
      • Don't try to disconnect cables by pulling on their wires, or you may damage them.
      • Use your fingers to grip the switch cable's white connector and pull it straight up and out of the socket.
      • If you're having trouble, use a spudger to push the connector up on alternating sides to "walk" it out of the socket.
      Ask FixBot
    2. Logitech RS Shifter & Handbrake USB Cable Replacement: step 10, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement: step 10, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement: step 10, image 3 of 3
      • Use tweezers to firmly grip the short edges of the USB cable connector and lift straight up to disconnect it.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      Ask FixBot
    3. Logitech RS Shifter & Handbrake USB Cable Replacement, Unclip the cables: step 11, image 1 of 2 Logitech RS Shifter & Handbrake USB Cable Replacement, Unclip the cables: step 11, image 2 of 2
      • Grip both cables together and pull them out of their plastic clip.
      Ask FixBot
    4. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the shifter assembly: step 12, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the shifter assembly: step 12, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the shifter assembly: step 12, image 3 of 3
      • Be careful not to press against the springs (with grease) near the screws.
      • Use a 3 mm ball-end hex key to remove the four 14 mm‑long screws securing the shifter assembly.
      • You may need to use tweezers to remove and install the screws.
      Ask FixBot
    5. Logitech RS Shifter & Handbrake USB Cable Replacement: step 13, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement: step 13, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement: step 13, image 3 of 3
      • The shifter assembly has grease spread on some components. Only grip the assembly by the back metal plate near the USB cable to avoid smearing grease.
      • Secure the base with one hand, and use your free hand to lift and remove the shifter assembly by the back plate.
      • During reassembly, make sure the two cables are routed out near the middle of the side their connectors are on.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the USB cable: step 14, image 1 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the USB cable: step 14, image 2 of 3 Logitech RS Shifter & Handbrake USB Cable Replacement, Remove the USB cable: step 14, image 3 of 3
      • Remove the USB cable.
      • During reassembly:
      • Use the second photo to ensure the cable is properly routed through the grooves on the base.
      • Make sure there are no gaps on the back edge where the rubber gasket meets the base.
      Ask FixBot
Spencer Day
206,261 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 77
All Time: 213
