Shop the Holiday Gift Guide
Logitech M275 Scroll Wheel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
14
Past 7 Days:
89
Past 30 Days:
282
All Time:
2,078
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Over time, the scroll wheel on your M275 Bluetooth Mouse Scroll Wheel may not be able to function correctly anymore. Follow this guide in order to correctly remove and replace the scroll wheel to get your mouse working again.
Tools
    1. Logitech M275 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Logitech M275 Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
      • Flip the mouse over.
      • With your fingers, gently press down and remove the battery cover.
      • Remove the battery and the USB receiver from the mouse.
      Ask FixBot
    2. Logitech M275 Scroll Wheel Replacement: step 2, image 1 of 2 Logitech M275 Scroll Wheel Replacement: step 2, image 2 of 2
      • Remove the sticker at the bottom of the battery compartment.
      • Use a Phillips screwdriver to remove the single screws at the bottom of the battery compartment.
      Ask FixBot
    3. Logitech M275 Scroll Wheel Replacement: step 3, image 1 of 1
      • Carefully remove the top half of the mouse cover.
      Ask FixBot
    4. Logitech M275 Scroll Wheel Replacement: step 4, image 1 of 2 Logitech M275 Scroll Wheel Replacement: step 4, image 2 of 2
      • Use a spudger or screwdriver to carefully apply upward pressure around each side of the circuit board until the whole piece slides out of the bottom.
      Ask FixBot
    5. Logitech M275 Scroll Wheel Replacement: step 5, image 1 of 1
      • Using a soft cloth, gently remove dust and small debris.
      Ask FixBot
    6. Logitech M275 Scroll Wheel Replacement: step 6, image 1 of 3 Logitech M275 Scroll Wheel Replacement: step 6, image 2 of 3 Logitech M275 Scroll Wheel Replacement: step 6, image 3 of 3
      • Carefully remove the wheel from its axis and replace it with the new wheel.
      Ask FixBot
    7. Logitech M275 Scroll Wheel Replacement: step 7, image 1 of 3 Logitech M275 Scroll Wheel Replacement: step 7, image 2 of 3 Logitech M275 Scroll Wheel Replacement: step 7, image 3 of 3
      • Ensure that the new scroll wheel is aligned with the encoder.
      • Make sure that the new scroll wheel spins and clicks into place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Adrianna Doan
166 Reputation
1 Guide authored
UC Davis, Team 2-4, Whithaus Spring 2025 Member of UC Davis, Team 2-4, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G4
3 Members
12 Guides authored
1 Guide Comment
Worked perfectly! Thanks.
Also, a quick tip: In my case the mouse wheel was not working properly. Due to tear, scrolling was very erratic. In step 6, I was able to repair the existing wheel by applying a tiny ammount of PVA glue on the smaller axis side (the one that goes into the encoder), which works as makeshift bushing.
Philippe Sevestre - Reply Share
Past 24 Hours: 14
Past 7 Days: 89
Past 30 Days: 282
All Time: 2,078
