Logitech K480 Metal Plate Replacement
    1. Logitech K480 Metal Plate Replacement, Back Cover: step 1, image 1 of 1
      • Flip the keyboard over.
      Ask FixBot
    2. Logitech K480 Metal Plate Replacement: step 2, image 1 of 3 Logitech K480 Metal Plate Replacement: step 2, image 2 of 3 Logitech K480 Metal Plate Replacement: step 2, image 3 of 3
      • Remove the four rubber feet with a spudger.
      Ask FixBot
    3. Logitech K480 Metal Plate Replacement: step 3, image 1 of 3 Logitech K480 Metal Plate Replacement: step 3, image 2 of 3 Logitech K480 Metal Plate Replacement: step 3, image 3 of 3
      • Slide open battery panel.
      • Remove the batteries.
      Ask FixBot
    4. Logitech K480 Metal Plate Replacement: step 4, image 1 of 2 Logitech K480 Metal Plate Replacement: step 4, image 2 of 2
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech K480 Metal Plate Replacement: step 5, image 1 of 2 Logitech K480 Metal Plate Replacement: step 5, image 2 of 2
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech K480 Metal Plate Replacement: step 6, image 1 of 3 Logitech K480 Metal Plate Replacement: step 6, image 2 of 3 Logitech K480 Metal Plate Replacement: step 6, image 3 of 3
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      Ask FixBot
    1. Logitech K480 Metal Plate Replacement, Metal Plate: step 7, image 1 of 3 Logitech K480 Metal Plate Replacement, Metal Plate: step 7, image 2 of 3 Logitech K480 Metal Plate Replacement, Metal Plate: step 7, image 3 of 3
      • Remove the eight 3 mm screws using a Phillips #00 screwdriver
      • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
      • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Metal Plate Replacement: step 8, image 1 of 2 Logitech K480 Metal Plate Replacement: step 8, image 2 of 2
      • Lift up and remove the metal plate.
      Ask FixBot
Kristen Gismondi
109,389 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 53
All Time: 393
