Shop the Holiday Gift Guide
Logitech G535 Ear Pads Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
47
Past 30 Days:
162
All Time:
1,169
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to remove and replace one or both of the ear pads (aka ear cushions, headset cushions, or headphone cushions) on your Logitech G535 headset.
    1. Logitech G535 Ear Pads Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech G535 Ear Pads Replacement, Remove the ear pads: step 2, image 1 of 3 Logitech G535 Ear Pads Replacement, Remove the ear pads: step 2, image 2 of 3 Logitech G535 Ear Pads Replacement, Remove the ear pads: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the left ear pad.
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      Ask FixBot
    1. Logitech G535 Ear Pads Replacement, Install the ear pad: step 3, image 1 of 3 Logitech G535 Ear Pads Replacement, Install the ear pad: step 3, image 2 of 3 Logitech G535 Ear Pads Replacement, Install the ear pad: step 3, image 3 of 3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Author
with
Arthur Shi
353,633 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 162
All Time: 1,169
