Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Use angled tweezers to peel up and remove the sticker covering the bottom-right speaker plate screw.
Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
Use your fingers to swing the speaker plate to the side of the housing, making sure not to strain the cable.
Use tweezers to firmly grip the edges of the battery connector.
Gently rock the connector side-to-side and slide it out of its socket.
Insert the flat end of a spudger underneath the battery.
Pry gently to release the battery from the ear cup.
Remove the battery.
Tool used on this step:Tesa 61395 Tape$2.95
Use your fingers to peel the foam pad from the battery.
Transfer the pad onto the replacement battery.
Apply a strip of double-sided tape to the foam pad.
Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
