Introduction
Go to step 1 ↓Follow this guide to replace the tether and trident cable on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Use your hand to gently pull the face gasket straight off of the headset.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
15 other people completed this guide.
4 Guide Comments
Thanks, the clip was giving me problems and this gave me the confidence that I was on the right path. :D
Again this autor doesn't understand the meaning of replacing, he just shows us how to dismantle the headset, not how to reinstall it correctly. Useless guide...
@jasonbouchard Install by following the steps in reverse....it's not rocket science
