Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓The Nintendo Switch comes with two Joy-Con controllers. This guide shows how to replace the joystick of the left Joy-Con. The procedure for repairing the right Joy-Con is different, so be sure to follow the correct set of instructions for your controller.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Video Overview
Tool used on this step:Magnetic Project Mat$19.95
Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
Tool used on this step:Tweezers$4.99
The ZL button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock opposite the cable.
Use tweezers to gently pull the ZL button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
Use your fingers to pull the thumbstick off of the Gulikit joystick module.
1098 other people completed this guide.
166 Guide Comments
Thx This really helped
Thanks. This was just the right amount of info and now my left stick drift is gone….for now.
I would recommend at least once a month take a can of compressed air and spray the joystick internals to clear it of any dust or debris.
