Shop the Holiday Gift Guide
Logitech G435 Battery Steps
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
27
All Time:
186
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Logitech G435 battery removal and installation steps. This prereq requires the ear pads removal/installation prereqs to be complete.
Parts
Tools
    1. Logitech G435 Battery Steps, Remove the screw sticker: step 1, image 1 of 2 Logitech G435 Battery Steps, Remove the screw sticker: step 1, image 2 of 2
      • Use angled tweezers to peel up and remove the sticker covering the top-left speaker plate screw.
      Ask FixBot
    2. Logitech G435 Battery Steps, Remove the speaker plate screws: step 2, image 1 of 1
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
      Ask FixBot
    3. Logitech G435 Battery Steps, Secure the speaker plate: step 3, image 1 of 3 Logitech G435 Battery Steps, Secure the speaker plate: step 3, image 2 of 3 Logitech G435 Battery Steps, Secure the speaker plate: step 3, image 3 of 3
      • Don't try to fully remove the speaker plate—it's still attached by some wires.
      • Use your fingers to swing the speaker plate out of the housing.
      • Use some tape to secure the speaker plate to the headband. This keeps the speaker plate out of the way while preventing the speaker wire from being strained.
      Ask FixBot
    4. Logitech G435 Battery Steps, Remove the circuit board screws: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove the two 4.6 mm‑long screws securing the circuit board.
      Ask FixBot
    5. Logitech G435 Battery Steps, Detach the circuit board: step 5, image 1 of 3 Logitech G435 Battery Steps, Detach the circuit board: step 5, image 2 of 3 Logitech G435 Battery Steps, Detach the circuit board: step 5, image 3 of 3
      • The circuit board is still connected by many wires. Be gentle as you move the board to prevent damaging any wires.
      • Use your fingers to lift the circuit board slightly out of its recess.
      • Flip the circuit board over so you can access the underside.
      Ask FixBot
    6. Logitech G435 Battery Steps, Disconnect the battery: step 6, image 1 of 3 Logitech G435 Battery Steps, Disconnect the battery: step 6, image 2 of 3 Logitech G435 Battery Steps, Disconnect the battery: step 6, image 3 of 3
      • Use tweezers to firmly grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide it out of its socket.
      Ask FixBot
    7. Logitech G435 Battery Steps, Remove the battery: step 7, image 1 of 3 Logitech G435 Battery Steps, Remove the battery: step 7, image 2 of 3 Logitech G435 Battery Steps, Remove the battery: step 7, image 3 of 3
      • The battery is lightly adhered to the ear cup.
      • Insert the flat end of a spudger underneath the battery.
      • Pry gently to release the battery from the ear cup.
      • Remove the battery.
      Ask FixBot
    8. Logitech G435 Battery Steps, Transfer the battery pad: step 8, image 1 of 2 Logitech G435 Battery Steps, Transfer the battery pad: step 8, image 2 of 2
      • Use your fingers to peel the foam pad from the battery.
      • Transfer the pad onto the same side of the replacement battery.
      Ask FixBot
    9. Logitech G435 Battery Steps, Attach the battery: step 9, image 1 of 3 Logitech G435 Battery Steps, Attach the battery: step 9, image 2 of 3 Logitech G435 Battery Steps, Attach the battery: step 9, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
      Ask FixBot
    10. Logitech G435 Battery Steps, Reconnect the battery: step 10, image 1 of 2 Logitech G435 Battery Steps, Reconnect the battery: step 10, image 2 of 2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      Ask FixBot
    11. Logitech G435 Battery Steps, Install the circuit board: step 11, image 1 of 2 Logitech G435 Battery Steps, Install the circuit board: step 11, image 2 of 2
      • Use your fingers to gently flip the circuit board back over its recess.
      Ask FixBot
    12. Logitech G435 Battery Steps: step 12, image 1 of 3 Logitech G435 Battery Steps: step 12, image 2 of 3 Logitech G435 Battery Steps: step 12, image 3 of 3
      • Align the circuit board notch on the right side of the USB-C port to the ridge on the ear cup.
      • Insert the circuit board at a downward angle and guide the USB-C port into its cutout.
      • Press the bottom edge of the board against the ear cup and tilt the board down.
      • This is a tight fit, as the board has to clear the screw post next to the port to be properly seated.
      Ask FixBot
    13. Logitech G435 Battery Steps: step 13, image 1 of 1
      • Use a Phillips screwdriver to install the two 4.6 mm‑long screws to secure the circuit board.
      Ask FixBot
    14. Logitech G435 Battery Steps, Install the speaker plate: step 14, image 1 of 2 Logitech G435 Battery Steps, Install the speaker plate: step 14, image 2 of 2
      • Use your fingers to swing the speaker plate back into place.
      Ask FixBot
    15. Logitech G435 Battery Steps: step 15, image 1 of 1
      • Use a T5 Torx driver to install the four 6.1 mm‑long screws to secure the speaker plate.
      Ask FixBot
Author
with
Arthur Shi
353,975 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 27
All Time: 186
