Logitech G27 Shifter Potentiometer Replacement
  1. Logitech G27 Shifter Potentiometer Replacement, Shifter Potentiometer: step 1, image 1 of 1
    • Remove the six 9.0mm allen screws with a 2.5mm hex key.
  2. Logitech G27 Shifter Potentiometer Replacement: step 2, image 1 of 1
    • Either use the plastic opening tools or a flat screwdriver to pry and pop off the cap on the shifter.
  3. Logitech G27 Shifter Potentiometer Replacement: step 3, image 1 of 2 Logitech G27 Shifter Potentiometer Replacement: step 3, image 2 of 2
    • Remove the black 12.3mm screw inside the shifter with a Phillips #1 screwdriver.
    • After, remove the shifter top and shifter boot cover by pulling straight up.
    • Remove the three 15.6mm screws with a Phillips #1 screwdriver.
  4. Logitech G27 Shifter Potentiometer Replacement: step 4, image 1 of 1
    • Flip the device over and four 15.6mm screws with a Phillips #1 screwdriver.
    • Pull the lower clamp up and out of the shifter assembly.
  5. Logitech G27 Shifter Potentiometer Replacement: step 5, image 1 of 3 Logitech G27 Shifter Potentiometer Replacement: step 5, image 2 of 3 Logitech G27 Shifter Potentiometer Replacement: step 5, image 3 of 3
    • Remove the two 10mmm hex nuts with a 10mm socket and a ratchet.
    • Next, unscrew the clamps by holding the lower portion of the shifter and unscrewing the top part.
    • Also remove the nut on the screw if it wasn't removed with the lower clamp.
  6. Logitech G27 Shifter Potentiometer Replacement: step 6, image 1 of 1
    • Remove the eight black 11.9mm screws from the bottom housing with a Phillips #1 screwdriver.
  7. Logitech G27 Shifter Potentiometer Replacement: step 7, image 1 of 2 Logitech G27 Shifter Potentiometer Replacement: step 7, image 2 of 2
    • Carefully lift the top half of the housing from the bottom.
    • Watch out, there are 2 wires attached to the PCB board. Be careful not to damage these in any way.
  8. Logitech G27 Shifter Potentiometer Replacement: step 8, image 1 of 1
    • Carefully remove the two plastic connectors with a plastic opening tool or your hands.
  9. Logitech G27 Shifter Potentiometer Replacement: step 9, image 1 of 1
    • Go to the lower portion of the shifter; remove two black screws and four silver 15.9mm screws with a Phillips #1 screwdriver.
  10. Logitech G27 Shifter Potentiometer Replacement: step 10, image 1 of 2 Logitech G27 Shifter Potentiometer Replacement: step 10, image 2 of 2
    • There is grease covering the whole shifting assembly so it will get messy when removing.
    • Squeeze the two metal plates together and slowly pull up. The assembly is spring loaded and will fall apart if it is not squeezed.
  11. Logitech G27 Shifter Potentiometer Replacement: step 11, image 1 of 2 Logitech G27 Shifter Potentiometer Replacement: step 11, image 2 of 2
    • Remove the shifter assembly and place it on a flat surface. Then remove the metal plate with the spring and ball bearing attached.
    • This is the hardest part of reassembling. Make sure to properly place the spring inside of the inner housing and the ball bearing on top. Place the other metal piece on top of it.
  12. Logitech G27 Shifter Potentiometer Replacement: step 12, image 1 of 3 Logitech G27 Shifter Potentiometer Replacement: step 12, image 2 of 3 Logitech G27 Shifter Potentiometer Replacement: step 12, image 3 of 3
    • You will now have access to the two potentiometers on the sides of the assembly. Make sure they are properly connected and if need be, replace them by removing.
Nicholas Gholdoian
1,159 Reputation
2 Guides authored
Cal Poly, Team 15-4, Amido Spring 2015 Member of Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Members
25 Guides authored
Past 24 Hours: 12
Past 7 Days: 100
Past 30 Days: 455
All Time: 57,484
