Introduction
If your Logitech G27's shifter stops responding, you may need to replace the potentiometer inside it. The potentiometer is the electrical component that keeps track of which gear the shifter is on. The replacement isn't too difficult, you mostly just have to unscrew lots of screws.
Either use the plastic opening tools or a flat screwdriver to pry and pop off the cap on the shifter.
Remove the black 12.3mm screw inside the shifter with a Phillips #1 screwdriver.
After, remove the shifter top and shifter boot cover by pulling straight up.
Remove the three 15.6mm screws with a Phillips #1 screwdriver.
Flip the device over and four 15.6mm screws with a Phillips #1 screwdriver.
Pull the lower clamp up and out of the shifter assembly.
Remove the two 10mmm hex nuts with a 10mm socket and a ratchet.
Next, unscrew the clamps by holding the lower portion of the shifter and unscrewing the top part.
Also remove the nut on the screw if it wasn't removed with the lower clamp.
Go to the lower portion of the shifter; remove two black screws and four silver 15.9mm screws with a Phillips #1 screwdriver.
Squeeze the two metal plates together and slowly pull up. The assembly is spring loaded and will fall apart if it is not squeezed.
Remove the shifter assembly and place it on a flat surface. Then remove the metal plate with the spring and ball bearing attached.
You will now have access to the two potentiometers on the sides of the assembly. Make sure they are properly connected and if need be, replace them by removing.
