Logitech G Cloud Left Joystick Replacement
    1. Logitech G Cloud Left Joystick Replacement, Case: step 1, image 1 of 2 Logitech G Cloud Left Joystick Replacement, Case: step 1, image 2 of 2
      • Power the device off and turn it over so the screen is face down.
      • Insert an opening pick into the seam between the back plate and left handguard.
      • Pry around the entire perimeter until the handguard fully releases.
      • Remove the handguard.
      • Repeat the previous three bullets on the right handguard.
      Ask FixBot
    2. Logitech G Cloud Left Joystick Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
      Ask FixBot
    3. Logitech G Cloud Left Joystick Replacement: step 3, image 1 of 2 Logitech G Cloud Left Joystick Replacement: step 3, image 2 of 2
      • Insert an opening pick into the seam between the midframe and rear case.
      • Gently pry the rear case upwards to separate it from the midframe.
      Ask FixBot
    4. Logitech G Cloud Left Joystick Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
      Ask FixBot
    5. Logitech G Cloud Left Joystick Replacement: step 5, image 1 of 2 Logitech G Cloud Left Joystick Replacement: step 5, image 2 of 2
      • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
      • Gently pry out the midframe by lifting an opening pick.
      • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
      Ask FixBot
    1. Logitech G Cloud Left Joystick Replacement, Left Joystick: step 6, image 1 of 2 Logitech G Cloud Left Joystick Replacement, Left Joystick: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 10 mm screws that secure the L2 trigger.
      • Pop the L2 trigger out with your fingers.
      Ask FixBot
    2. Logitech G Cloud Left Joystick Replacement: step 7, image 1 of 3 Logitech G Cloud Left Joystick Replacement: step 7, image 2 of 3 Logitech G Cloud Left Joystick Replacement: step 7, image 3 of 3
      • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
      • The sticker should stay attached to the joystick plate.
      • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
      • Use a spudger to remove the L2 trigger sensor from the joystick plate; it should stay attached to the console.
      Ask FixBot
    3. Logitech G Cloud Left Joystick Replacement: step 8, image 1 of 2 Logitech G Cloud Left Joystick Replacement: step 8, image 2 of 2
      • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
      • Pop the joystick out with your fingers.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 129
All Time: 1,138
