Introduction
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the top handle portion of the joystick.
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Carefully pry apart the joystick chassis by hand.
Careful to release this clip located underneath the hand rest
