Introduction
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the top handle portion of the joystick.
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber cover to reveal the two screws underneath
Remove the two 10 mm screws revealed after moving the rubber cover, using a Phillips screwdriver #1
Carefully pry apart the joystick chassis by hand.
Careful to release this clip located underneath the hand rest
