Logitech Extreme 3D Pro Base Button Circuit Board Replacement
  1. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the handle: step 1, image 1 of 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 2, image 1 of 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 3, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 3, image 2 of 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the base: step 4, image 1 of 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 1 of 3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 2 of 3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 3 of 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: step 6, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: step 6, image 2 of 2
    • Remove this wire plug head from this circuit board.
    • Removing this wire frees the base piece to make working on it easier.
  7. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 7, image 1 of 1
    • Remove the two 10mm Phillips #1 screws from the button board.
  8. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 8, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 8, image 2 of 2
    • Lift up the circuit board.
    • Remove this plug head to free the board.
Emanuel Canela
1,297 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 3,629
