Logitech Ergo M575S Battery Replacement
    1. Logitech Ergo M575S Battery Replacement, Turn off your mouse: step 1, image 1 of 1
      • Before starting, flip the power switch on the bottom of your mouse down, so it's in the OFF position.
      Ask FixBot
    2. Logitech Ergo M575S Battery Replacement, Remove the battery cover: step 2, image 1 of 3 Logitech Ergo M575S Battery Replacement, Remove the battery cover: step 2, image 2 of 3 Logitech Ergo M575S Battery Replacement, Remove the battery cover: step 2, image 3 of 3
      • Push the battery cover's center tab in and up to remove the cover.
      Ask FixBot
    3. Logitech Ergo M575S Battery Replacement, Remove the battery: step 3, image 1 of 3 Logitech Ergo M575S Battery Replacement, Remove the battery: step 3, image 2 of 3 Logitech Ergo M575S Battery Replacement, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, check the sticker in the recess to ensure you insert the battery in the proper orientation.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
205,923 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 77
All Time: 344
