Logitech Dual Action Joystick Replacement
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: step 1, image 1 of 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 1 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 2 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 3 of 3
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 1 of 2 Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 2 of 2
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Brian Neuman
908 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
3 Guides authored
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 144
All Time: 9,973
