Lite-On LightScribe SHM-165H6S Chassis Replacement
  1. Lite-On LightScribe SHM-165H6S Chassis Replacement, Chassis: step 1, image 1 of 2 Lite-On LightScribe SHM-165H6S Chassis Replacement, Chassis: step 1, image 2 of 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • The tray should click open, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Chassis Replacement: step 2, image 1 of 3 Lite-On LightScribe SHM-165H6S Chassis Replacement: step 2, image 2 of 3 Lite-On LightScribe SHM-165H6S Chassis Replacement: step 2, image 3 of 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Chassis Replacement: step 3, image 1 of 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Chassis Replacement: step 4, image 1 of 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Chassis Replacement: step 5, image 1 of 2 Lite-On LightScribe SHM-165H6S Chassis Replacement: step 5, image 2 of 2
    • Lift the top and bottom chassis straight up in order to remove them.
James Biggs
596 Reputation
3 Guides authored
Cal Poly, Team 6-5, Regan Fall 2011 Member of Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,812
