Lenovo Yoga Book X90F Battery Replacement
  1. Lenovo Yoga Book X90F Battery Replacement, Bottom Screen/Keyboard: step 1, image 1 of 1
    • Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
    • New adhesive will be required when completing the steps in reverse order.
  2. Lenovo Yoga Book X90F Battery Replacement: step 2, image 1 of 2 Lenovo Yoga Book X90F Battery Replacement: step 2, image 2 of 2
    • Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
    • While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
    • The screen may crack easily as it is thin and fragile.
  3. Lenovo Yoga Book X90F Battery Replacement: step 3, image 1 of 1
    • While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
  4. Lenovo Yoga Book X90F Battery Replacement: step 4, image 1 of 3 Lenovo Yoga Book X90F Battery Replacement: step 4, image 2 of 3 Lenovo Yoga Book X90F Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
    • If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
    • You can find more information on Zero Insertion Force (ZIF) connectors on this guide.
  5. Lenovo Yoga Book X90F Battery Replacement: step 5, image 1 of 1
    • Separate and remove the bottom screen from the device.
  6. Lenovo Yoga Book X90F Battery Replacement, Battery: step 6, image 1 of 3 Lenovo Yoga Book X90F Battery Replacement, Battery: step 6, image 2 of 3 Lenovo Yoga Book X90F Battery Replacement, Battery: step 6, image 3 of 3
    • Using a JIS #0 screwdriver, remove the single 8 mm screw.
    • Disconnect the battery cable from the motherboard.
  7. Lenovo Yoga Book X90F Battery Replacement: step 7, image 1 of 1
    • Use the opening pick to remove the two black strips on each side of the battery so the battery is cleared of any obstructions.
  8. Lenovo Yoga Book X90F Battery Replacement: step 8, image 1 of 2 Lenovo Yoga Book X90F Battery Replacement: step 8, image 2 of 2
    • The battery is glued down to the frame of the computer.
    • Wedge the opening pick underneath the battery and work your around the battery.
  9. Lenovo Yoga Book X90F Battery Replacement: step 9, image 1 of 1
    • Once the adhesive begins to unstick from the battery, remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 other people completed this guide.
Parker Mumaw
157 Reputation
1 Guide authored
Clemson, Team 5-2, Hunter Fall 2021 Member of Clemson, Team 5-2, Hunter Fall 2021
CLEM-HUNTER-F21S5G2
5 Members
8 Guides authored
7 Guide Comments
Make a plan to replace the keyboard/second screen after installing a replacement battery.
Mark Rohde - Reply Share
How to calibrate the battery?
Janet Davidson - Reply Share
I like how the screen is broken in the pictures from step 1 to step 2. :P
emmerycheung - Reply Share
Thanks for the writeup! too bad the cost of replacement parts make this repair almost not worth the effort. =(
Jonathan Lin - Reply Share
Excellent but i find nowhere an explanation of how to reassembly, mainly how to adhere the keyboard glass surface to the base chasis. I mean, is still usable the same original adhesive heated in the first step or a two sides adhesive frame has to be placed after removing the old adhesive (or just aplying a sort of glue -¿wich one?-). I’ not sure I’ve made it clear, I hope yes. Thanks in advance.
Cesar - Reply Share
Past 24 Hours: 0
Past 7 Days: 26
Past 30 Days: 119
All Time: 10,555
