Lenovo ThinkPad P51s RAM Replacement
    1. Lenovo ThinkPad P51s RAM Replacement, RAM: step 1, image 1 of 2 Lenovo ThinkPad P51s RAM Replacement, RAM: step 1, image 2 of 2
      • Flip the laptop so the bottom is facing up.
      • Place it on a soft cloth so you don’t scratch the lid.
      Ask FixBot
    2. Lenovo ThinkPad P51s RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad P51s RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad P51s RAM Replacement: step 2, image 3 of 3
      • Slide both locking latches outward using your thumbs.
      • Keep the right latch held in the unlocked position with your right thumb. With your left hand, pushed the battery out of its placement from the slot.
      • Once it detaches, use both hands to slide the battery out.
      Ask FixBot
    3. Lenovo ThinkPad P51s RAM Replacement: step 3, image 1 of 2 Lenovo ThinkPad P51s RAM Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to loosen all seven captive screws that secure the lower case.
      • Do not try to remove the captive screws. They should remain in the bottom case.
      Ask FixBot
    4. Lenovo ThinkPad P51s RAM Replacement: step 4, image 1 of 3 Lenovo ThinkPad P51s RAM Replacement: step 4, image 2 of 3 Lenovo ThinkPad P51s RAM Replacement: step 4, image 3 of 3
      • Insert an iFixit opening tool into the gap along one edge of the laptop.
      • Gently slide it around the perimeter to release the clips.
      • Work slowly and avoid twisting the tool to prevent cracking the cover or bending the frame.
      • Lift the bottom cover off once all clips are released.
      • Metal tools can crack the plastic clips—use only plastic prying tools.
      Ask FixBot
    5. Lenovo ThinkPad P51s RAM Replacement: step 5, image 1 of 3 Lenovo ThinkPad P51s RAM Replacement: step 5, image 2 of 3 Lenovo ThinkPad P51s RAM Replacement: step 5, image 3 of 3
      • Push the two metal retaining clips on each side of the RAM module outward.
      • The RAM stick will pop up at a 30 degree angle.
      • Hold the edges of the RAM card and gently slide it out from the slot.
      • Do not touch the gold contacts skin oils can cause connection failures.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 250
