Lenovo ThinkPad P50 SSD Replacement
  1. Lenovo ThinkPad P50 SSD Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad P50 SSD Replacement, Battery: step 1, image 2 of 2
    • Slide the battery latch to the left to unlock it and remove the battery.
  2. Lenovo ThinkPad P50 SSD Replacement, Bottom case screws: step 2, image 1 of 1
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
  3. Lenovo ThinkPad P50 SSD Replacement, Bottom case: step 3, image 1 of 2 Lenovo ThinkPad P50 SSD Replacement, Bottom case: step 3, image 2 of 2
    • Lift the lower case up and off of the chassis.
  4. Lenovo ThinkPad P50 SSD Replacement, SSD: step 4, image 1 of 1
    • Remove the 4.4 mm Phillips #00 screw securing the SSD.
  5. Lenovo ThinkPad P50 SSD Replacement: step 5, image 1 of 2 Lenovo ThinkPad P50 SSD Replacement: step 5, image 2 of 2
    • Slide the harness backwards, then pull it out.
  6. Lenovo ThinkPad P50 SSD Replacement: step 6, image 1 of 2 Lenovo ThinkPad P50 SSD Replacement: step 6, image 2 of 2
    • Remove the 3.7 mm screw securing the SSD to the harness with a Phillips #00 screwdriver.
  7. Lenovo ThinkPad P50 SSD Replacement: step 7, image 1 of 2 Lenovo ThinkPad P50 SSD Replacement: step 7, image 2 of 2
    • Lift the drive up at about a 35 degree angle and pull out to remove it from the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
609 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 394
