Lenovo ThinkPad P50 Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
32
Past 30 Days:
157
All Time:
1,194
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your device is no longer typing like it used to you may need to replace the keyboard. Fortunately, replacing a damaged Keyboard is often more straightforward than it seems. This guide will walk you through the essential steps to safely remove and replace your laptop keyboard using simple and straightforward steps.
Parts
Tools
    1. Lenovo ThinkPad P50 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad P50 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Slide the battery latch to the left to unlock it and remove the battery.
      Ask FixBot
    2. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case screws: step 2, image 1 of 1
      • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
      • The screws will not come all the way out; do not attempt to remove them from the case.
      • Pull up the notch with your fingernail or a spudger.
      Ask FixBot
    3. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: step 3, image 1 of 2 Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: step 3, image 2 of 2
      • Lift the lower case up and off of the chassis.
      Ask FixBot
    1. Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: step 4, image 1 of 2 Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: step 4, image 2 of 2
      • Remove the following screws with a Phillips #00 screwdriver:
      • Seven 5.7 mm screws
      • Five 4.3 mm screws
      • Three 12.6 mm screws
      Ask FixBot
    2. Lenovo ThinkPad P50 Keyboard Replacement: step 5, image 1 of 2 Lenovo ThinkPad P50 Keyboard Replacement: step 5, image 2 of 2
      • Turn the computer over and open the lid.
      • Insert an opening pick in the seam between the keyboard bezel and chassis.
      • Pry around the entire perimeter until the keyboard assembly fully releases.
      Ask FixBot
    3. Lenovo ThinkPad P50 Keyboard Replacement: step 6, image 1 of 3 Lenovo ThinkPad P50 Keyboard Replacement: step 6, image 2 of 3 Lenovo ThinkPad P50 Keyboard Replacement: step 6, image 3 of 3
      • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
      • Detach the connectors that connect to the trackpad.
      • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
      • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      Ask FixBot
    1. Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: step 7, image 1 of 2 Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: step 7, image 2 of 2
      • Lift the keyboard slightly until you see the cable connection the keyboard to the rest of the computer
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
609 Reputation
5 Guides authored
1 Guide Comment
This guide is woefully incorrect. You do not need to remove the palm rest in order to replace the keyboard. This is a great way to end up with a cracked palm rest if you're not careful. Please refer to the manufacturer's support guide here: Page 68 has the relevant material.
Shane Welsh - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 157
All Time: 1,194
