Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement
  1. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Remove rear casing: step 1, image 1 of 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Remove rear casing: step 1, image 2 of 2
    • It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove
  2. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, detatch the old digitizer cable: step 2, image 1 of 1
    • Using your fingernail or tweezers lift the holding flap and disconnect the digitizer cable for the old screen
  3. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: step 3, image 1 of 3 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: step 3, image 2 of 3 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Removing the old Broken Glass/Digitizer: step 3, image 3 of 3
    • Please be very careful!, This glass shatters easily and shards will go flying if you are rough
    • The glass is connected to the frame and LCD by the world's strongest adhesive, .... took me well over an hour to remove the old screen
    • Using a heat gun (high powered blow dryer) or those of you lucky enough to have an iopener kit slowly heat your way around the glass, start in a corner and work your spudger in.
    • Make sure you slide your spudger straight in to avoid the lcd There is a nice gap but the adhesive is two part!
    • Clean your Edges
    • Using your spudger or a razor knife clean off any left behind adhesive
  4. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Install new Glass/Digitizer: step 5, image 1 of 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Install new Glass/Digitizer: step 5, image 2 of 2
    • Carefully Slide the digitizer cable through the opening in the case
    • Flip over case and reconnect the new digitizer cable
    • I then tested to make sure the screen and digitizer worked before adhesive :)
  5. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Adhere your new screen: step 6, image 1 of 2 Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Adhere your new screen: step 6, image 2 of 2
    • The Screen I ordered came with adhesive already on it, but I added some 3M tape too
    • Press the Screen firmly into place
    • Then replace the back cover!
  6. Lenovo Tab 2 A10-70 Front Glass and Digitizer Replacement, Finish!: step 7, image 1 of 1
    • Test your work and Be proud, not an easy task but you completed it!!!!
Amber Wooldridge
539 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 42,726
