Introduction
By the end of this guide, you will be able to remove the back panel from the laptop.
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a PH1 bit on your screwdriver, begin by removing the top five (30 mm) screws underneath the battery.
Using a plastic opening tool, make your way around the edge of the laptop.
There is a visible line between the bottom shell of the laptop and the laptop body itself.
Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
