Lenovo Ideapad Flex 15 Bottom Panel Replacement
  1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: step 1, image 2 of 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 2, image 1 of 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 2, image 2 of 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 3, image 1 of 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 3, image 2 of 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 3, image 3 of 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 4, image 1 of 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 5, image 1 of 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 5, image 2 of 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 5, image 3 of 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 6, image 1 of 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: step 6, image 2 of 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
3 other people completed this guide.
Brent
804 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,842
